forced induction guys
ZmanM3
The Evil One
Jackson, NJ
I have been running a Wide band, Fuel Pressure and Boost Vac gauge since I put the S/C on. I have also added 2x dual scan Areoforce gauges and a oil pressure gauge. If I were to do it over again I'd probably just go with the 2x Areoforce gauges and add the sensors to get wide band, fuel pressure, oil pressure and boost vac off them.
snakebit05
thats the set up i think iam going to end up getting oh and do you like it would be easier to just buy the hoses for the s/c from saleen other then say getting some and making them myself? i have the metal hoses just need the rubber ones
ZmanM3
The Evil One
Jackson, NJ
I'd get them from Saleen or better yet On3 performance as they actually still answer the phone.
bigstick
Tri-Cities, MI
Any reason why you're not running gauges? The reason I'm asking is that I don't really like the idea of putting a pillar pod on my car or one of the pods on top of the dash and I'm not sure how the heat and air are affected by the Roush pods. However, I'm worried about not being able to see if I'm running lean or not. I guess with a good tune, it really wouldn't matter, but I certainly don't want to hurt my car.
Autometer Cobalt: digital Wideband A/F, Analog boost/vac also.
Mine have been mounted in Roush Pods for about 2 years now. I love the look, but not sure I would recommend. You lose the air flow control in the pods once you install the gauge. And worse, condensation forms inside the gauge face in certain weather conditions. My digital wideband display is starting to malfunction because of it.
snakebit05
i like how that looks but i had a feeling that would happen with those since the cold air blow right on to them.
yea i know ordered a 3.8 pulley on the 13th with 3 day shipping and still havent got it yet. ill call on3 tomorrow and see what else i may need im sure ill have it all after the gauges and the hoses
Chino
03 Mach 1 & 08 GT
SOS triple pod:
Autometer Cobalt Boost Gauge
Aeroforce Interceptor
Innovate LC-1 wideband
Roush AC vent pod:
Autometer Cobalt Nitrous Pressure Gauge
If I had to do this all over again I'd go you dual Aeroforce gauges and get the boost sensor and tie my wideband into one of the analog inputs. On the Mach 1 I have an NGK AFX wideband done this way and really cleans up the dash. The Aeroforce gauges can also be setup to warn at preset levels like too high and A/F or too low a voltage.
snakebit05
yea i saw that on the video thats one of the many reasons why i want to get those kinda gives you a security blanket i guess haha blew me away that those gauges had so much adjustably i can already tell its going to be money well spent.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
VEISystems digital dual widebands, oil pressure, fuel pressure, coolant temp, i/c coolant temp, boost/vac.
snakebit05
nice set up texas love the color of your car i used to have a p3 myself but i totaled it last year:( so now i have a mineral grey one i guess i need to make a sig on here with a pic.
Phuck Phace
Dallas
The Interceptors are super nice but kind of hard to read in the daytime. I have mine mounted in the SOS pod and it's super pimpin
Turbostangs90
TEXAS
I have the dual SOS pillar mount.
1 aeroforce showing Fuel PSI, and Wideband
1 Boost/Vac gauge
JerryC
Memphis TN
Air comes around the Roush pod but it is reduced by a good amount and you cant aim it. There was a note that came with my Aeroforce that you can overheat the gauge when using the car heater and blowing through the vent. I have had that setup for a year and never had a problem staying cool in the summer or not using the vents in winter.
If you get the Autometer beveled rings to put behind your gauge(s) you can angle them so you see them better. This has been a huge plus with the Aeroforce in the vent pod.
