Fore Precision introduces the Stock Line Adapter!
STACYSTANGZ
Raleigh NC
[FONT=Arial Narrow,Arial MT Condensed Light,sans-serif]
S197 Fuel Rail Stock Line Adapters are here!
[/FONT]
[FONT=Arial,Helvetica,sans-serif]
A Design Like No Other!
Made by Fore Precision, the S197 Stock Fuel Line Adapter is a design like no other.
The S197 Stock Fuel Line Adapter was fully developed to support the style and performance of the Fore Precision Fuel Rail collection.
As a customer, you will receive special pricing on the S197 Stock Fuel Line Adapter when ordering the Fore Precision Fuel Rail Performance Kit.
The S197 Stock Fuel Line Adapter includes ALL the necessary pieces to plug into the factory fuel line feed.
The S197 Stock Fuel Line Adapter comes with a 1/8 NPT plug, so no need to buy additional components for a fuel pressure gauge or nitrous system.
Fore Precision uses a different approach by incorporating swivel connector to the adapter to create an easy install and accessible tightening pattern.
Clearly the full-anodized construction of this piece is the highest strength and offers a long lasting cosmetic finish.
The S197 Stock Fuel Line Adapter includes Viton o-rings and PTFE seals, which is found impervious to high heat, pressure, and all ethanol and other racing fuels.
The S197 Stock Fuel Line Adapter uses the OEM inlet location by allowing OEM fuel lines to plug in without twisting or binding. This super low profile design easily clears coolant crossover lines and intake casting.
Fore Precision always guarantees perfection and quality driven products.
[/FONT][FONT=Arial,Helvetica,sans-serif]
[/FONT]
[FONT=Arial Narrow,Arial MT Condensed Light,sans-serif]S197 Fuel Rail Stock Line Adapter
(3V)
Available for the late model S197, the Fore Precision S197 Adapter allows you to easily use your factory stock fuel lines. These beautifully machined pieces will help you maintain a sleek look with your fuel rails from the Fore Precision Fuel Rail Collection.
Retail: $85
Available in 2010, special pricing on the adapter when ordering fuel rail set.
Complete kit with cross-over lines coming soon!!!
[/FONT] [FONT=Arial,Helvetica,sans-serif][/FONT] [FONT=Arial,Helvetica,sans-serif]
[/FONT]
[/FONT]
(GT500)
The GT500 Fuel Rail Stock Line Adapter was created to add a unique design to your Shelby GT500. The adapter allows an easy install by plugging into the stock factory fuel line with
not limiting the OEM location. The adapter
also obtains a low profile look that matches
the beauty of the Fore Precision Fuel Rail.
Retail $ 55
[SIZE=+0]Available in 2010, special pricing on the adapter when ordering fuel rail set.
[SIZE=+0]
[/SIZE]
[/SIZE]
[/FONT]
doogie
SE WI
Very nice!
Does the adapter swivel where it attaches to the rail or does it lock into place once tightened?
Chris07GT
Tampa, FL
So what exactly do I need to order to be able to use your fuel rails with my stock lines? Is the installation straight forward?
STACYSTANGZ
Raleigh NC
It depends on the application, but the broad approach is:
Fore Precision's Stock Fuel Rail Adapter
Fore Precision's Low Profile AN -8 Port Plug
with O Ring,
which we have for $7.95
One Teflon Cross over hose
2 additional Port plugs
Another option is to contact your favorite S197Forum Performance Vendor to view their Fore Precision Fuel Rail Kits.
STACYSTANGZ
Raleigh NC
Let us know if you have any questions!
Fore Precision is the same company that brought you the ONLY three pump in-tank solution to Modern Mustangs.
“Manufactured for your Mustang!”
