Compare location and style of sensors...be prepared to change them over if different.
If the car is a manual trans, the flywheel will be different. Somewhere in '07, Ford started using a dual-mass flywheel. The 2 can be interchanged, but must be done as a set (flywheel/pressure plate/clutch disc).
