frpp 47# injectors m-9593-lu47
onebadgsx
Houston, TX
these are the injectors that come with the frpp whipple kit for 2011-2012 gt's. i believe these are the same that come on the gt500 as well
I have an 08 mustang with a Whipple I Jst need some new ones
The whipple kit comes with 32lb frpp injectors in ev14 length like mentioned above.
Part Details
Hover over image to zoom
click to enlarge
FORD RACING 32 LB/HR FUEL INJECTOR SET
M-9593-MU32*
Suggested Retail Price
$350.00
Sold in Units of:
Eight Pack (8)
tech notes
  • 32 lb/hr, 4-hole, high-impedance fuel injector with USCAR electrical connector
  • Original equipment on 2005-2006 Ford GT
INJECTOR NOTES:
  • Medium length injectors are for use in GT500 or Ford GT. We also use the MU32 in our 3v supercharger kits.
  • The long injectors are the more common length and are applicable to all non-GT500 Mustangs since multi-port injection was introduced
    [*]Wrong electrical connector for your application? Try our M-14464-A8 Fuel Injector Adapter Kit
    [*]Need help determining which injector you require for your application? Refer to EFI Tech Tips
The seller is selling ev6 length injectors.
crownaviation
http://www.tudyno.com/
Broke dafuk down
47lb GT500 injectors
Up to 30% Off MSRP
all Ford Parts & Accessories
Home » Mustang » 2005-2009 Mustang Accessories & Racing Parts » Ford Racing Parts » Engine & Power Upgrades » M-9593-G302 » Ford Mustang 47Lb/Hr Injector Set
$220.00 MSRP: $319.00Savings: $99.00 (31%)
Original equipment on 2007-2010 SVT Mustang
Specs. 47 lbs/hr. 11-18 ohms M USCAR M-14464-A8 Black w/yellow stripe
Sold in a set of 8 INJECTOR NOTES:
47 lb/hr, 6-hole, high-impedance fuel injector with USCAR electrical connector
Wrong electrical connector for your application? Try our M-14464-A8 Fuel Injector Adapter Kit About electrical connectors:
The USCAR connector is sometimes referred to as EV6, which is a Bosch term for the generation of injector.
Jetronic is the older style connector, sometimes referred to by the Bosch generation EV1.
Neither EV1 or EV6 is technically correct because those generations of Bosch injectors could come with either connector.
However most EV1’s commonly seen use the Jetronic connector and most EV6’s use the USCAR connector so it’s easy to see the connection.
onebadgsx
Houston, TX
Click on my link above. These are used in the 2011 -up whipple kits.
I used these to run e85 when i was na. Also can be used when paxton/vortech when running stock pulley. Those kits also come with 47lbs in the full kits
