FS: BMR adjustable Panhard Bar
Modshack
Greenville NC
Virtually new. Only on the car for <1000 miles (went to a Watts Link and no longer needed). Center (on car) adjusters and poly ends with grease fittings. $100 + $15 FedEx. Can take Paypal or Credit card. Save $40
Email me: [email protected]
From the Late Model Restoration listing:
The 05-Present Mustang Panhard Bar is responsible for locating the rear end side-to-side in the chassis. Factory Mustang Panhard Bars are made with small diameter tubing and rubber bushings that allow deflection under load. BMR Mustang Panhard Bars are all made from larger diameter 1.25", heavy wall DOM tubing and utilize either greaseable polyurethane bushings or HD spherical bearings by QA1. The adjustable versions use left-hand and right-hand thread to allow easy "on-car" adjustment. BMR's CNC machined adjusters are made from 4130 chromoly and have rolled threads. All rod end spacers are 304 stainless. You won't find better quality pieces.
By nature, a Mustang Panhard Bar will alter rear end position as ride height changes. This makes it necesarry to use an Adjustable Panhard Bar when lowering your vehicle as it allows you to re-center the rear end. Adjustable Panhard Bars also become a "must-have" part if you are trying to fit the widest tires possible in the wheelwell. Available in Black Hammertone or red powdercoat.
__________________
Redfire_WNL
THE BEAST UNLEASHED!
TAMPA, FL
If this is still for sale next Friday consider it sold, I need this piece bad. GLWS!!!
