FS: Performance Automatic 5r55s Deep Pan with Dip Stick *NIB*
Legend Shaker
Chicago, IL
How deep is it internally... was wondering is it gonna hit a speed-bump, I would like to see what specs are but none to be found. Please let me know the internal depth and overall depth if possible. Thank you,
Sal Valdes
Hi Sal,
I am traveling for work right now and do not have access to the Pan. It's about 7" internal depth.
I will ask my Son to measure it next time he visits and get back to you in a couple days. 7 inches is a fairly accurate estimate.
Legend Shaker
Chicago, IL
Sal Valdes
Here ya go... some info that I found... it hangs about 1.5 to 2" lower than the stock factory Pan.
Made in the USA
PRODUCT DESCRIPTION
Performance Automatic of Gaithersburg Maryland proudly announces the release of their new deep aluminum pan for the Ford 5R55 N, S and W series transmissions. This transmission is the primary 5-speed rear wheel drive automatic for many vehicle lines including the Ford Explorer, Ranger, Lincoln LS and the 2005-2010 Mustang.
Cast from high strength aluminum alloy and increases fluid capacity by 4 quarts on the 5R55. It will hang roughly 1.5" -2" lower than the factory pan.This pan will also allow the use of Performance Automatic's new matching transmission filler tube and dipstick. This eliminates the need for a special tool as well as the messy and often incorrect factory fill procedure. Fluid level checks and refills can now be made under the hood, not under the car!
Legend Shaker
Chicago, IL
I will be returning home over the weekend. Now would be the time to get what's left of my parts, so I can get them shipped out of if local? Then pick up.
Thanks,
Michael
