Great! Glad you found it...Hooray!! My guy found the problem and everything is now working correctly.
Hooray!! My guy found the problem and everything is now working correctly. Just have to put the entire interior of the car back together and will be back where we were two weeks ago. One of the wires from the PCM back to the fuel pump modules had somehow gotten chaffed and there were only about 4 filaments in a 10 filament wire that were not cut. The wire would check for continuity, because it was not grounding out, but would not carry the required voltage so the PCM would throw a code and not fire the pumps. He found it by tracing the wire and checking the voltages the entire length of the car. I won’t make FFW with the car now but at least I will get it running.
Earl
