I am at a dead stop currently in my TT install as we can't get the fuel pumps to fire. Got everything hooked up and turned the key on to check the fuel system for leaks and the pumps will not turn on. Have been going through everything for a week now and it all checks out, the wiring is correct, the diagnostic checks all show good but the PCM will not turn on the pumps. We even tried the stock setup and it’s the same. If you disconnect the pumps at the tank every check is good, once you connect the pumps you get a fuel control module out of limits code. If the pumps are wired direct they work so the pumps are good and both modules check out good. Needless to say I am very frustrated. Anyone have any ideas?
Earl
Earl
