Fuel's Winter Project: Build It Before It Blows
Hiltsy845
At TVD, gates typically open at 9 on Saturday & 8 on Sunday. They start running cars about 2 hrs after. Waiting on a response & I'll let you know for sure.
Update - They will run cars from noon till 6ish both days.
JoshK
Modder AKA Fuel
Nebraska
I am going to try to get up there by 3:00 on the Saturday the 26th. I already have a trailer lined up.
I also finally got myself a gopro gentlemen, hopefully it will be nice out this weekend and maybe I can get a vid or two of the car.
JoshK
Modder AKA Fuel
Nebraska
Well I decided to go out and make a quick walk around vid just to test out the GoPro I got. Here it is. Stay tuned
Kidd
Berea KY
What up and down pipes are you running Josh? I would really like to get my turbo up higher like yours.
JoshK
Modder AKA Fuel
Nebraska
Decided to re-activate the N2MB tonight and make an actual vid. New to the GoPro, so trying different mounting locations and what not soon.
JoshK
Modder AKA Fuel
Nebraska
Me too! If you watch the vid in full screen you can see the numbers on the boost gauge(left vent pod). I had the 2 step set at 4200rpm and it got up to 6lbs when I let it go. You can also see how fast it goes from vacuum to full boost. With the full 3" exhaust all the way back, I can definetly tell a difference from the 3 to 2.5" y-pipe and 2.5" catback from last year. You can tell there is NO backpressure issues with this setup. Paul did a great job with this kit, and with the dynomax 3" catback behind it, it flat out flows.
JoshK
Modder AKA Fuel
Nebraska
^^Exactly. Go back and read through this thread again. This is not a $10k engine, and it makes PLENTY of power.
Kidd
Berea KY
Haha thanks guys, I'm ready to get it going again. Doing some research right now to see if buying a block and build it would be much cheaper then buying a built SB.
Sorry for the thread jack Josh lol
