thump_rrr
When I first installed the blower I was at 10lbs of boost riding on 26x11.5-17" M/T E.T.Streets on factory rims.
My 60' times generally ran between 1.58 and 1.63 dpending on the condition of the track.
I then switched to a set of Weld XP 15x9 rims and a set of M/T E.T. Street Radials in 275/50-15" which netted me a best 60' of 1.52.
The problem with this setup was that I was running out of gear around the 1000' mark once I increased the boost to 12psi. The reason I didn't go back to the radials was that I could only get around 65 runs out of a set while I can get at least 2 times as many on the bias ply.
Last year I switched to a 28" M/T E.T. Drag which is when my problems started. By switching to the 28" tires I began to rub the fenders unless the rear shocks were set to full firm. My 60' times were all over the place and on a good day with perfect track prep I could only manage a best 60' of 1.64.
This spring I purchased a set of 15x10 Bogarts with the proper offset so that I could once again soften up my rear suspension for better weight transfer. I also installed the BMR Swaybar relocation brackets to clear the Bogarts and I switched from a set of BMR LCA Relocation Brackets to a set of Steeda ones for more adjustability. My 60' times are still all over the place with a one time best of 1.68 and are usually in the 1.77 range.
My suspension setup has not changed except for the relo brackets.
Can a set of tires get too old?
Should I be looking for something else?
The pinion angle is set at -2º
