gt500 dual fuel pump harness....help!?
ARMORINE
tulsa, oklahoma
hey folks my new N/A stroker motor is nearing completion so i need to get humping on the fuel system. I've basically given up on finding a gt500 harness so I'm going to have to build one/ run wires for the second FPDM and the plan falls apart on step one. I'm a fantastic engine mechanic but wiring makes me want to claw my eyes out. I've searched the forums looking for a walk through or any threads on people that have done this but so far have come up empty, my search fu is weak. any help would be greatly appreciated.
heres what ive got so far:
gt500 fuel pump.
2nd FPDM is on the way.
ordering the division X gt500 pump pigtail tommarow
if any one has a good diagram that would be a massive help...i had one but this project got derailed a while back and ive managed to lose it.
thank you
v6tungsten
Wylie, TX
Ill post it in a few minutes...need to locate it on my home pc
cFhgpdsvrErvoK0snWExB9IZeDSi6su7rBuE8vsR8SNt6fFB8TAuILBGYRkWr3zJXjvOZMvD0hFKMobFHZMp93E0_TCl-DwkY1xO2NXmJrbkhGCm_2RRp9jGd-MOsuhWaOvswzFBrC0Tcagy_uvYzJnY2RszwVmrHdzapOMrsYRVZxp4PmF1vL3zRyEXDd_3EQtxRVEKailFUmiAlxQt1QwkwUWuthsdTiEfNDKF5etFkvso6pRQUrtRyQcQarO8Njjs_b3SeA5wLWqwcVVcArhjCU1hJQ51LI162HyUOF1WD_V3gUWzjD_41D6UgeQ3cMKmRdIYhS45VGdYGU4yqcQuiNJp4EjNXT38YIDIZiK0597BL7wto6Nm5RpL4yKoMe8ibpU5J7Vmd7Ryn0XmY6FkYkXibVszoILHDk8AOf0Amn2uzH3dE9DLG6Y7o73KV_76hYrORycIR75IhbY__7ZKcagv1jH-RzGn_PRsi7hbce_qZ1x49qvA_xzH3vSo6QqBXMBE0uY86aAvSVlpBmv4Q9SyWpYc9dovolvj9_omT_LuB_op_3btz_DW9WneCA-u5fk7tcKlqFF-APQto6CRhc_LJkcevyx6FBtx6lCX3zlE=w800-h634-no
ARMORINE
tulsa, oklahoma
only question i have is about the 5 pin relay. i just wire into it in the trunk im assuming. is there any particular model relay?
It's not much different than a relay for anything else. Make sure the amperage is sufficient, use the original fuel pump power wire to the relay coil to preserve the safety power off switch just like doing a power wire upgrade.
I've used a few different ones over the years for different combos. I always buy two and keep one as a spare just in case. I think the brand in my car right now is "Painless". Not sure it matters much, they are probably just repackaged from some bulk supplier.
