Driftstang22
Cali
In need of help please. I have a 2007 gt with a fuel pump issue that i feel like I’ve tried everything to fix. Backstory i bought this car really cheap to make a drift car out of. When i initially got the car i tried to start it and it ran terrible spit popped and banged had a laundry list of codes. After looking the car over i found some smashed O2 wires in between the bell housing and engine block. Repaired the wires. Car still didn’t run good. Then I noticed every time i turned the key over without starting the car the fuel pump would run and never hit its prime and shut off. I ended up replacing the FPDM the fuel pressure sensor and the fuel pump. Still same issue was there. After further trouble shooting i got it down to the computer being bad. I bought a refurbished computer and the same problem still exists. I am unsure on what direction to go next. Any help is much appreciated. Thanks for your time.
You could try swapping the fuel pump relay with another relay in the under hood fuse box and see if that resolves it. If it does, replace the bad relay.
Midlife Crises
Fairbanks, Alaska
You found damaged wires for the O2 sensors. I wonder if the wires have been mixed up and not connected to the correct location.
