Good morning everyone.
Here is the background of my car. It's a 2010 GT with a procharger P1-SC, duel gt500 fuel pumps with a upgraded power line to the fuel pump relay.
The issue I've been having is I notice on tip in of the throttle my wideband would go pretty lean (17-18) then rich (11-12) and finally stabilize at 14.8. That's when you crack the throttle. So I data logged with one of my friends and we noticed that as soon as you open the throttle a little it cut voltage going to the fuel pumps for a split second and then kicks in like normal. Under normal driving each shift the fuel pump voltage is fine.
Checked the fuel pump relay and noticed it was melting a little so I replaced it with a 40A 12V relay. Also upgraded my ground wire as well, but the problem still continues.
I'm pretty much at a lose right now. Any ideas you can throw at me? I'm going to check the whole power line from the fuse box back to the relay to make sure it's not pitched or split anywhere.
