amustangrocks
had to replace my frt control arms. i could see the frt tires leaning in on the tops, and at 100,000 it was past time. kinda trashed the insides of my tires by not doing it sooner. the rubber bushings seemed really soft and beat too. i got the frpp arms from am. also doing it realized the boots were cracked on each tie rod end so i ordered 2 from rock auto today.
replacing the arms was kinda a pita for just a few bolts. i blasted the nuts off for the rack that you have to move to get the arm bolts out and realized they may have been tack welded to the frame, oops. the new arms and bushings really tightened the frt end back up, but the alignments off, and the wheel is off a little too. guess i`ll wait for the tie rods to get it straightened out. with the rack unit how do you adjust the tierods? i should be able to get it closer than it is right now till i get it to a shop.
