Headlight Adjuster
saleen836
Across the pond!
As title, is it possible to purchase the adjuster seperate from the actual headlight unit ?
A friend has an '06 model and one of his is broken, have tried searching but being in the UK some sites in the US are blocked
86GT351
Sunny South Florida
Message me the complete VIN and I will see if I can get an answer for you.
WJBertrand
Maybe you can find a breaker/dismantler that has a car with damaged headlight but with a good adjuster on it?
Sent from my iPhone using Tapatalk Pro
xeninworx
You could always try and epoxy the adjuster back on. If not, take the headlight apart and repair from the inside then reassemble the headlight. Or just buy some aftermarket set.
saleen836
Across the pond!
Being in the UK the chance of finding one is very slim
Are your friend's lights HID?
No standard lights
The adjuster just pulls out and has parts missing so is broken, he is going to bodge it for now and buy some aftermarket headlights
pass1over
I like it LOW
Trenton, FL
If the lights from Flusher won't work ...
I think I have a standard set of headlights for a project I tried out and didn't work.
Is it the entire internals that's the adjuster for these? I forget what it looks like. If it's just some inside part you need, I would be happy to take it out and send it to you. They're just going to sit on my shelf and collect dust until eternity.
