That was me in your other thread. Here's what I quoted:For anyone interested in the build, I have decided on a crank. Thanks to another member commenting on another post pointing out the max safe rpm of each stroke available (assuming 5,000ft per min is a safe piston speed).
Your real limiting factor is going to be piston speed. A longer stroke will necessitate a lower rev limit in order to keep the mean piston speed to no more than 5000ft/minute (what the best all forged bottom end production engines are achieving).
3.80" stroke = 7900rpm
3.75" stroke = 8000rpm
3.65" stroke = 8200rpm (MMR 4.75L stroker crank which is modified Coyote crank)
3.54" stroke = 8500rpm (stock stroke of Modular 4.6)
Therefore your best bet would be to use a Ford Performance Boss 5.0 iron block for its larger 3.70" cylinder bore size in order to maximize valve area and head flow without valve shrouding, while using a stock 3.54" stroke forged crank e.g. '03-'04 Cobra Terminator unit.
The highest revving production (and race) engines are generally "oversquare" with a bigger bore and a shorter stroke. The aforementioned combination will yield a cylinder displacement of 304.8ci or 4994cc (5.0L), which is the same as Ford's famous 5.0L Cammer engines except the Cammer was built on a sleeved Modular aluminium block.
Since you've decided to go with the MMR 4.75 crank (same 3.65" stroke as Coyote and almost identical to 3.66" stroke of the 8200rpm 5.2L Voodoo), I think you now know where your maximum rpm will need to be.
Ideally you'll want the biggest bore possible, which is why I initially suggested the Boss 5.0 Modular iron block. Otherwise you'd be stuck with a 3.572" bore (+0.020" overbored 4.6L block) that'll shroud the valves of Livernois stage 3 CNC ported 3V heads and hobble head flow.
As for the choice of compression ratio, that'll depend on the grade of fuel you'll want to run when boosted. If it's 93 octane pump gas, I'd suggest sticking with something close to the stock 9.8.
Your other limiting factor is going to be the valve train. The phasers will need to be locked out completely or you'll need to go for 2V cam sprockets instead. You'd also need custom cams.
