Help! Headlight LED Stripes not working
msthandi
Toronto
Hi Everyone, I have a 2014 Mustang with the below headlight assembly. the LED Stripes have stopped working on the passenger side.
Do I need to replace the whole headlight? if not, does anyone know how i can fix this? any help is greatly appreciated!
DieHarder
Need to isolate the problem down to the cable/connector or LED element. Pull the plug and test for 12v/Gnd with a test light or VOM. If you have 12v at the plug it's likely the element which is usually not serviceable so yes, you're looking at a new headlight but I'd troubleshoot first in case it's something else like SJB (not sure how 2014's are wired). Unfortunately, don't have a manual for a 2014. Maybe someone else does.
pass1over
I like it LOW
Trenton, FL
More than likely you're going to need a whole new headlight. And be prepared, OEM ones are NOT cheap if you have HID headlights
