I think you all are making a mountain out of a molehill.
You know what I'm doing to my FR-S that's on KW Coil-overs for the winter? I put Blizzaks on it. Done.
I don't get the issue here, maybe I'm missing something.
Right now I have a stock '12 brembo gt. Only mod is a one-piece DS.
I'm using the stock rims w/ winter tires.
I want a better handeling suspension, dampers in particular.
I have Yellows w hd mounts, P springs, front and rear(25mm) strano sways, and a panhard.
I want to install the yellows w/ P spring in front and 55d in the rear, with sways to get through the winter.
In the spring, I'll put on my staggered wheels w/ sticky rubber. At that point I'll be replacing the 55d rear spring w/ the P spring and putting in LCA's, adjustable UCA, and possibly relo brackets.
The whole reason I want to put the P srings in the front now is so I don't have to take out the front strut again in the spring.
Thanks for everyones advice.
