Help me plan my attack on P0443, P0446 and others
CJ-
from California
Ok on and off for the past year my 2005 GT has suffered from the periodic combination of P0443, P0446’s and other times a combination of Evap system small leak detected, large leak detected and check gas cap.
So I’m fabricating a smoke device out of a paint can, Incense and some hoses to help locate any leaks if they exist.
I need help figuring out how to go about implementing this smoke machine, should I hook up the smoke outlet hose to the evap purge valve outlet tip, inlet hose that leads to the charcoal canister...? I don’t really know where to start.
RocketcarX
95% of my weight is fuel
Colorado
boomer9999
Buffalo, NY
I hooked the smoke up to the brake booster hose on my F150. Found a pinhole in the top of the fuel tank.
  • Like
Reactions: CJ-
