My plan is to take off the PRO 5.0 and put the stocker back in just to see if the PRO is the cause to some shifting issues. So I take the Spyder DS out and look at the underside of the shifter. I notice the tranny linkage arm can be moved ever so slightly side to side where the shifter bolts to it. Same on the tranny end. I can rotate the brass(?) spacers with two fingers. I was careful not to over tighten the nut since I already stripped one shift linkage arm and had to replace it. I can't remember the torque for that nut, but I didn't make it very tight and used loctite.
Is it right for those spacers to rotate like that? This could be the metal rattling I'm hearing/feeling through the shift handle under load. Didn't some people use the stock spacers to get rid of some NVH? I don't think those will work though, I don't believe they're wide enough.
Thoughts/advise please....
