Help with water leak!!!!
Speed+Clinic
New Orleans, LA
Help with water leak!!!!!
I have a drivers side water leak coming from the foot well area.
Things I have changed or done:
1. cleaned out the drain plugs from the engine bay.
2. changed the window plastic trim seal.
it seems to be getting in from the pedal area. My driver's side cowl cover have like a 1/4 inch gap by the middle and it does not sit flush close to the left of the body.. Would that cause the leak or should I look for somewhere else?
The area where the cables come into the cabin was slightly cut years ago to make room for the boost controller and wideband but those have been removed since then but I cannot pin point if it stared leaking since I removed those cables. If it rains it gets soak but it gets really wet if I drive in the rain. Any ideas or thoughs would be greatly appreciated
