tmcolegr
It's All About the Build
So today I ran the 3 battery (welding) cables through the interior of the vehicle back to the trunk. For those that have done this before I am sure you can appreciate that this, if done neatly and correctly, is easier said than done on a vehicle which still has all the factory interior installed. Prior to running these cables the floor pan should be carefully inspected for burrs sticking up that could puncture the jacketing on the cable and create a short circuit. All cables were routed laying flat on the floor pan. None of the cables were crossed and all 3 of these cables were loosely tie strapped together to keep them in the original location that they were installed in. All carpeting and interior trip panels have been reinstalled and there are no telltale signs of these cables running under the carpeting. Passenger seat still adjusts fore & aft without any interference from the cables. Here's some pictures
I am planning on mounting the battery in the center of the trunk compartment directly behind the rear seats. Here the spot I'm referring to.
Trunk mat has temporarily been reinstalled while I wait for the Odyssey billet aluminum battery tray, battery and battery disconnect switch to arrive
I know y'all are going to find this impossible to believe, but currently I have about 16 hours invested in this project (8 hours in the planning and locating all the components I intend on using and another 8 hours of installation to get to this point) and expect to have another 8 hours to complete this project. Still have the battery & battery tray to mount, custom fuse panel/disconnect switch panel to fabricate and install, and completion of all the battery cables back in the trunk compartment.
