The high speed fan relay burnt twice this week. All the information I could find online suggested adding universal relays..
So i installed the relay last night.. I also added 2 indicator lights. The blue light was terminated on the normally closed circuit so i could see when the relay was on or off ( if the relay is off the light would be on, if the relay was on the light would be off)... The green light just showed that I had power going to the fan, when the relay was on.
Well upon finishing I took the car for a ride. The fans came on and off throughout the drive.
Now, here is where im having a hard time understanding whats going on.. I was under the impression that computer sends a ground signal to the relay and that a constant 12v's is what turned on the relay..If thats true my blue light should of went off, but it never .
I checked voltage. I found that the normally closed and normally open circuit had power on them.. As if the relay was not fully seated in either direction. I checked the coil and had 12v's on both sides..
That is where im hung up, why does it seem the computer is sending 12v, what kind of signal does the computer send?
Im considering just puting a switch in it and not relying on the computer.. Should i remove the low speed relay and just run high ?
