Jinx
Photography Blogger
One thing I couldn't stand about my old 3v Whippled car was the anxiety that came from running that blower with a build bottom end. Cost was the problem at that point and the first time owning a FI car. With that said and attempting to plan out what I want to do, I have formulated a few questions. I have searched but most thread containing info on a build seem to revolve around bulletproofing and high expense. I love reading the threads about Bruce's multiple 3v builds (I love to see him with a coyote at some point), but I havent seen a cost effective (in the sense of building for what he is targeting) DIYer like him rebuild a coyote. Usually I search and see threads about shortblock or longblock swaps or all out builds. The closest I've seen is one fellow on SVTP with a boss shortblock build. So that leaves me with a few questions before jumping into a coyote project.
-If buying a low mileage (under 40,000) car is a deck plate bore and honed really that necessary? Couldn't a simple home ball hone be good enough?
-Same low mileage car, same simple ball hone, wouldn't a boss piston/ring/rod combo set, TSS billet oil pump gears, clevite bearings, and boss valve springs be more that enough insurance for a beefcake special. Lol.
^thoughts on this idea:
-Ive read that the oil pump gears, due to harmonics from a
blown application and increased engine RPM, usually are
suspect before the rods on roadrunner engine.
-this combo seems to leave the stock block itself the weakest
link; but at that point you would have to be pushing 800.
Basically the idea is reusing a young block to make a homegrown boss stock block with TSS oil pump gears and boss springs to have insurance at an increased rpm.
While drooling over multiple build ideas the FI route with it plentiful power on tap is always most appealing. However considering my worries on my last FI car; a build seems to be on the wishlist.
It seems smart to build it up before failure.
I like to hear ideas on this.
