I thought it was aluminum? I have the common problem of paint not sticking to the underside. The paint on the topside was not terrible, although it took a beating Virginia from sand and gravel.
I've seen PDR guys work miracles, but that could be tricky because of the corner and that the hood is double layered in that spot (they can't just knock it out from the backside)
Spoke to a local body shop and they are going to attempt to mold the stock hood back into shape. They weren’t excited on the thought of an aftermarket fiberglass hood due to too many fitment issues in the past so we will see where it goes!
Will post pics when it’s done (scheduled about a month from now).
Hood repair finished this week. I think it turned out great for being the same hood.
Painter said it should be good to hand wash since it was baked in 140 degrees (car is filthy from sitting out in the rain) but anyone have recommendations on how long I should wait before washing?
As long as the car wash soap is free of wax and silicone you should be fine to wash now. Definitely no Wax or silicone anything for 6 weeks so the paint can out-gas.
You can check bottles for wording like "paint shop safe". I think I used the Meguiars purple soap after I got mine painted
if its 2k lacquered then its good to wash with a soft non acidic formula, as said in post above don't seal the paint with polish or ceramic coating before the solvents have evaporated.
