Horn relay
Will51
Vancouver, WA
I've been having an issue with my horn the last few months. Sometimes it works fine, sometimes it doesn't work at all. Usually when it won't work, if I hold it down long enough it will start to work. Every time I push the horn, whether it works or not, I can here the relay clicking under the dash.
So I'm trying to find which relay goes to the horn, but, all I can find in the owners manual is the fuse for the horn, which, is obviously still good if the horns work sometimes.
Anyone know off the top of their heads which relay goes to the horns in a 2014 GT?
Will51
Vancouver, WA
I was able to find a schematic of the dash in the far corners of the internet, it appears the only relay is behind the dash best accessed by removing the radio. I hear it clicking under there, so chances are the relay is good and the horns are going bad or there's a bad ground at the horns.
I guess I'll just have to install some Hella Supertones on the car.
