The tank has been installed. I wired it to run when the key is in the on position, so the pump in the tank, and the fans on the HE can run without the car running. Man that Rule 2000 pump moves that water! seems even faster than when i had the remote mounted Meziere pump a year ago.
I also routed the lines a bit differently than most people do. I wanted to have the max cooling on the street (Tank>Heat Exchanger>Intercooler>Tank) but at the same time, when using ice at the track, have max cooling there as well (Tank>Intercooler>Heat Exchanger>Tank) without having to disconnect and reroute hoses. Well with all of my experimenting with the Killer Chiller, and having a temperature gauge reading the temp of the water AFTER it left the intercooler, I found that the water leaving the intercooler was, although not as cold as the water in the Killer Chiller/Tank, was still colder than the ambient air temperature. If the water travels out of the intercooler and has to pass through the Heat Exchanger, it will effectively heat the semi cold water to ambient temperature. It would be even worse so i feel with a dual pass HE like the Afco unit. What I did was install a set of Ball Valves, and bypass the heat exchanger for track use when using ice. By switching the positions of my ball valves i can effectively change the routing of the intercooler system so it goes Tank>Intercooler>Tank. Switch the ball valves to their previous position and its the OEM setup of Tank>Heat Exchanger>Intercooler>Tank. I feel I will have the best of both worlds with this.
I installed a Derale 13760 Transmission cooler to replace the one installed by FB. I wasn't able to mount it with the fan in a puller position so i ditched the fan and shroud completely and mounted it off center behind the grill, in front of the radiator. I have the fan and shroud on the side in case i want to move it somewhere else and have the room. The Derale is a Stacked plate design, while the FB one was a tube/fin design. The stacked plate design is super efficient in comparison. I was able to use one of the existing mounting holes that FB used, and drilled a second one and I am extremely happy with the result. Unfortunately i did not get any pics of it installed.
I reinstalled the CJ front springs as im gonig to the track on Monday, and man she looks like a 4x4 in the front again lol. the ride is so super smooth though lol.
Moving on, I got my blower back from Kenne Bell today. I had spoken to Jim Bell personally after they got my blower and he said he felt the unit didn't need a rebuild at all, so they cleaned it up, sent it back and threw in a bottle of oil for the blower as well. I threw it back on the car tonight. Car fired up right away and i took it for a test drive after checking for leaks, of which there were none.
After letting he car idle to temp i went driving for a while, no boost. I want to make sure the tank of gas that was in there over the winter with the Stabilizer in it is gone before i get into the power and boost. well I've never seen under 120-125 on my temps before for the IAT's and tonight it stayed between 95-100 all night. the highest i saw was 116, and that was with cruise control on, going downhill, so the throttle body was all but closed, not letting in any fresh cold air so it was to be expected. Id say mission success. The real test will be on Monday at the track so stay tuned for that. I will be running the race tune, and the 2.5" pulley on C16 for the first time. 9 Second runs are what I'm hoping for.
