Ok guys I need help! I've been searching and searching but I just can't seem to find an answer to my problem.
Tuesday leaving work my car wouldn't start. It would try but it just dies. I can give it gas to keep it alive and after about 30 seconds to a minute of me forcing it to idle it eventually finds its own idle.
Once it finds its own idle it runs like crap for about a minute then the idle smooths out and the car will then run perfect as if it didn't have any issues. It even drives fine as well. The idle doesn't surge when coming to stops or anything. And there is no loss in power what so ever!
Last weekend I replaced a plug that was misfiring and also found a torn injector o ring that was causing a vacuum leak. All the plugs where changed about 3 months ago with Autolite HT1s. Car was running fine last weekend after changing that single plug and o ring. There was still a tiny leak some where though but it wasn't affecting the car at all. Then Tuesday I started having this issue.
I found another torn injector o ring that was causing a leak and replaced that too. And it still won't start on its own. I can't find anymore vacuum leaks. I tried cleaning my MAF but still nothing. I tried swapping a friends MAF and also nothing.
The issue is only when trying to start the car. Once I get it running it idles and drives fine..
I'm getting 2 cels. P2196 and P2198 o2 sensor signal biased stuck rich. Both banks.
My mods are:
JLT CAI
Moto Blu Underdrive Pulleys
DIY CMDPs
Pacesetter Longtube Headers
Pypes O/R X pipe
SLP Power Flo catback
With tunes from Bama.
Sorry for the long post but I'm running out of ideas! Thanks in advance!
My mods are:
JLT CAI
DIY CMDPs
Pypes O/R X pipe
