installing sub and amp on 2011 gt help
darkstar november
magical turning mustang
ft lauderdale fl
getting some stuff togather, not so big on stereo stuff for a long time. what do i need wiring wise. anything special to get it to work with the oem head unit? im just doing a single alpine 10 in a small box, havent gotten an amp yep or wiring for it. just dont know where to start parts wise
2010Elanore
Honolulu, HI
just tap into the back 2 speaker wires...that is the easiest/best way imo. you will need rca's, power, speaker wire, and that is about it.
stang1971
Kansas City Mo
i used the wiring off the factory amps for the door subs for my signal... the factory radio puts out less bass as you turn it up.. the door signals are a little hotter and the bass doesnt cut out... my sub is twice as loud as it was with them tapped off the rear speakers.
drboyd
Awesome! Can you give us more detail about exactly which wires you tapped in to?
TIA!
dmhines
KONA GT
Cumming, GA
I'm getting a Amp and Sub installed tomorrow. I'll let you know how the installer wires it. Going to a privately owned car audio place ... $175 for the install which includes parts and labor. I am supplying Sub/Box/AMP.
Over the phone he said he will need to add a line converter and my Sub Volume will still be controlled by the Head Unit.
