I do wish you luck for sure.Well I had to go out and buy a drill and an extractor set. Drilled into the hole and then tried using an extractor only to have the tip of the extractor break off into the hole I just drilled out. So...I got a new extractor set and several dremel tips so I can get out the broken extractor and try a larger size. And it was craftsman drills and extractors, and getting new parts over-nighted to me from Vortech. Wish me luck!
I am taking my time, I even started with the smallest bit and worked up 2 size before trying the extraction. But I am a pretty persistant sob and I don't like failure.
Should be done any day now, they had to relocate my maf after the blower. I was recirculating so much air when not under a load it was causing a disturbance in the maf in its original position. So on the bright side i will vent my BOV to atmosphere now and waiting on the Anderson power pipe which is suppose to add a few pounds of boost. When it comes in Ill bring it back and get it retunedRisky, is your car tuned yet??
Amen, and I like you don't give up easy.
I Hate broken Bolts and having to mess with removing them.
Usually very time consuming ......
I come here as these Members are a lot more into Performance andnice to see you over here tiger!
95ragtopDay 3-The battle continues between myself and the broken extractor but progress has been made and it is almost out. My replacement parts arrived from Vortech only to be the wrong one, somewhere along the lines a U was dropped from the part number and I got the wrong part, so they will be in tomorrow. Right now I am sitting on some steps watching my motorcycle and car getting rained on while I drink a cold one. More to follow...
Glad to hear the SUN is out for You !!!!!!!!That thing is wild looking for an older bike, bet it was a handful. Looks like it is sunny again.
Modding than www.IMBOC.com Members.
Here these Members are into All Aspects of Performance with their Mustangs.
And as We Both know a Bullitt Mustang is just an Option on a GT Mustang.
There are some Very Serious Mustangs on this Site.........
Oh, and there are other Bullitt Mustang owners here also...........
Here and there. If you find your way on to www.moddedmustangs.com let me know I started a BULLITT crew over there.
