....not to trust ANYTHING posted by most everyone on this forum:
http://www.svtperformance.com/forum...-gt-auto-steeda-cai-tune-downshift-clunk.html
There are many comical errors in that thread but the one that takes the cake is post #8.
I'll give you a hint....the OP's car has a stock driveline meaning no driveshaft change. The driveshaft bolts onto the trans and to the pinion flange. This guy supposedly does all the work on his own stuff and doesn't know this?
He is the "TiVCT master", make no mistake about it.
What you are hearing is most likely the output shaft splines of the Trans banging against the drive shaft slip yoke splines. The fix is to properly grease the slip yoke splines as described in multiple vehicle line TSB's.
The reason why this is more pronounced with a tune is likely due to a combination of faster than stock downshifts and downshifting to a locked converter. Both normal for a performance tune.
The reason why a driveshaft caused the issue is very few driveshafts come properly greased.
An easy test is to place the vehicle in reverse and back up, before coming to a complete stop place it in drive. Do this a few times and you should hear the same clunk.
