SUHleen
Hey guys,
I'm getting a triple pump setup from On3 for my 05 mustang (keep the hating off the thread, Chad is local to me and I've known him for a while). I have a 2.6L kenne bell. I'm probably going to go turbo this winter, but want to see what I can do with my Kenne Bell and some e85 since if I do go turbo, I will be doing e85 so may as well do it now.
Currently, I am on a single pump Walbro drop in setup with 80 lb injectors, everything else fuel related is OEM. I know most if not all aftermarket fuel rails do not work with the Kenne Bell because the diverter valve hits. My question is, which of the fuel rails requires the LEAST amount of modification to fit? Or, has anyone found a set that will clear the diverter valve? I want to avoid doing the meth/nos plate that BBR sells because my hood clearance already is tight and I do not want to get into doing too much work if I do end up going turbo this winter.
Any ideas or thoughts?
