Article from Mustang 360 way back in 2006 on COXOC
5.0 Mustang & Super Fords
Klotz Coxoc Pump-Gas Power Additive
Testing Klotz Coxoc fuel additive in a 1990 Mustang LX
K.J. Jones
December 15, 2006
"Just pour this stuff in the fuel tank, and your car will run like it's (turbocharged, supercharged-fill in the blank)." We're all certainly familiar with the sometimes outlandish claims of incredible performance gains that are brought on by different brands of higher-octane gasoline and fuel "boosters" of various types. Yes-gasoline's octane rating certainly does play a key role in the horsepower mix. The higher the rating, the better (for making big power) seems to be the popular sentiment shared by most gearheads.
When it comes to the pump gas we use in our Mustangs, the octane rating-usually 87 to 93, with the exception of California where 91 is the maximum-represents the total amount of compression capacity the fuel has before it spontaneously ignites. So, using a naturally aspirated 'Stang motor as an example, its compression ratio is the variable that helps determine the correct octane required for making it run at its best. And as power adders such as nitrous, blowers, and turbos help raise the compression ratio of a 'Stang's engine, higher-octane gas is always a requirement-not an option-for making killer power.
Top Searches
- Cars
- News
- News
- Mustang
- Ford
Octane is definitely something the folks at Klotz Special Formula Products are familiar with, as the company makes 100- to 118-octane fuels, and even 100 percent, pure nitromethane (the stuff that powers NHRA Top-Fuel dragsters). While these fuel products are geared more toward hardcore racers and heavily modified Mustangs-not the daily drivers of the world-Klotz does make a pour-in-and-go fuel additive for street enthusiasts. The product is called Coxoc, pronounced "Co-Zoc," (PN KL-614; $71.00/gallon), and it goes against the grain when compared with other fuels and fuel enhancers in the Klotz lineup. According to company president, John Klotz, Coxoc basically increases combustion efficiency and promotes cleaner-burning exhaust by adding 37 percent more air (pure oxygen) into the fuel mixture.
More air helps make horsepower. That's another popular sentiment, but it's also one we endorse because we've proven it many times in induction and airflow tests. While the whole air-in-a-can thing seemed feasible to us when the concept was presented, what really intrigued us is Klotz's claim that the oxygen in Coxoc can be a benefit to modified 'Stangs that are on the edge with regard to passing state emissions tests. By sampling the number of hydrocarbons (measured in parts per million) and the carbon monoxide (measured in percent) of the car's exhaust, a state determines whether or not a vehicle is operating in compliance with SMOG laws.
With the help of U.S. Marines Gunnery Sergeant O. Carl White, (aka "Gunny" on many popular Mustang Web sites) and his 347-powered '90 LX, John Mihovetz and George Klass of Accufab for the dyno hookup, and Steve Abbruzzese and Eugene Walde of Westech Performance Center in Mira Loma, California, we conducted a performance test with Coxoc.
If you frequent any of the popular Mustang Web sites, you're probably familiar with the owner of this black '90 LX hatchback. Gunny's 'Stang hit Westech's SuperFlow chassis dyno packing a stock T5, 4.10s, and a Coast High Performance 347 Street Fighter with 10.8:1 compression that includes AFR 205 heads, a Trick Flow intake/75mm throttle-body combo, and Anderson Ford Motorsport's N-91 camshaft. Despite a rather restrictive (for that size AFR) header design and a chip that was made with more of a temporary, "get-it-to-run and-live-under-Gunny's-thrashing intent" rather than air/fuel levels and timing that were the result of extensive dyno tuning, which is recommended, Gunny's ride got with it in our baseline test, turning the drums with 341.30 hp and 325.70 lb-ft of torque.
Oxygen in a can. Westech's Steve Abbruzzese pours one gallon of Coxoc into the tank of Gunny's LX. Four gallons of fuel are required for each gallon of the additive. We used 91-octane fuel throughout our test. Klotz recommends running the engine for 5 to 10 minutes after adding Coxoc to give the ECM a chance to re-map itself with the additive in the fuel system. Manual timing adjustments are not required for EFI engines. Minor timing and jetting adjustments must be made when using Coxoc in carbureted applications. Pouring in the Coxoc resulted in peaks of 348.70 hp and 332.90 lb-ft of torque at the wheels.
When the moment of truth arrived, Klotz Lubricants' Coxoc impressed us, as it definitely stood up to its claim of being able to increase horsepower and torque with one can. The LX lit-up the dyno wheels with 367.1 horses at the rear tires, while torque improved to 351.5 lb-ft - a solid, 12.7 lb-ft gain which is impressive, especially since the engine's state of tune wasn't optimal.
We decided to keep tabs on air/fuel via the dyno's recording of air/fuel levels at the tailpipe (the Superflow chassis dyno employs a "sniffer" sensor, similar to that of state emissions testing equipment). Again, as seen in the air/fuel comparison in the accompanying chart, Coxoc actually did influence air/fuel, making the mixture leaner in the low-rpm range of our "with-Coxoc" dyno hit, than it was in the same rpm-band of our baseline.
Will Coxoc get a suspect 'Stang through a SMOG check? With most emissions tests performed at roughly 2,500-3,000 rpm (Gunny's mixture didn't get filthy rich - 9.9 and lower air/fuel until about 3,774 rpm with the additive in the tank, as opposed to 3,469 without it), it's highly possible that adding a can might help your borderline polluter blow clean at test time.
