Norm Peterson
corner barstool sitter
Without a shock dyno plot (or your own shock dyno), you probably can't assume anything better than "X" number of clicks or sweeps on will put you in the same place.How do you ensure that the damping is the same left to right?
Don't worry about what the C/Cc number might be.How do you get the damping to, say, 65% of critical as opposed to, say, 90% of it?
Obvious if you can notice the right things, which might be easier if there's a rapid sequence of corners that you can become very familiar with. You might find that enough less damping ends up feeling not quite as stuck down (for lack of better terminology) as when the damping is cranked up some. I'd guess that when further stiffening doesn't make the car feel any more stuck down and the car isn't trying to do anything bad, you might as well stop tinkering with the damping adjustment(s).Are such differences really going to be obvious even when your posterior is secure in the seat?
Curves of ride and performance vs % critical damping should generally look something like this ↓↓↓ . Oddly, P/Pmin is the ride curve and R/Rmin refers to roadholding performance. Note that these curves do not address the use of damping adjustments to solve vehicle transient issues.
If it matters any, with stock springs I haven't felt any need to go beyond 1.5 turns up from full soft up front or +1.25 turns in the rear (Koni yellows). I may try just a hair more front (rebound) damping with the new wheels and tires.
Norm
