Bud
good to get that license
Yup, shedding that newbie status one step at a time.
You going to be getting the car out this winter at all with the glide or waiting till spring?
thats pretty legit!
who did your converter? how sloppy is it? Turbo = Tight converter
I don't have a speedo or DS sensor so don't have it on my logs but getting as close as I can on rpm on the logs vs trap speed it looks like I had 13.75% converter slip in BG on the 8.84 run.
I definitely have to get a DS sensor going so I can get a better idea of slip next year. The Racepak obdii setup looks awesome if it'll pull what I need from the stock computer and allow me to add in a driveshaft and boost sensor. Would be nice to not have to try and hit a laptop button in gloves while strapped in to start logging.
SNAP! That's awesome. For use w older models too yes?
Change your name to Duece Bigalow, manwhore. Problem solved lol
Would still be nice to have the obdii sensor info from the PCM (maf, IAT, load, rpm, timing, etc) laid out on the same graph as boost, driveshaft speed, g meter without having to add redundant sensors/wiring.
It looks like some of the Racelogic stuff will do all that AND cameras.
Scaled the car again at it's full race weight. 3183lbs
With the ARB disconnected the corner weights were:
855 - 823
782 - 721
Put the ARB links back in and adjusted them while on the scales to get the weight showing on the rear the same for both sides and ended up with 762lbs on each rear tire. Problem is with the ARB adjusted to get the weight even in the rear the passenger side sits almost 1" higher than the driver's side.
When adjusting an ARB do you go for no preload and adjust from there or do you want to use it to even the weight out in the rear so each tire see's the same load?
Also I have to add 120lbs next year to be legal weight, thinking about putting some weight just behind the passenger seat until the car is the same side to side, then maybe the rest over the diff. Any suggestions on that?
I would not recommend preloading the sway bar like that. We always run ours neutral if you start preloading the car will always be cocked over one way and the suspension will not beable to move freely. with it cranked up like that you are putting way too much load on that little 5/16s heim joint. Think about that you have that little sucker trying to move 60 LBS in your case.
If you set in neutral with the car at race weight with driver you should beable to hop under the car and easily move either link. (they should wiggle back and forth and hit the mount.)
If you want to even out the weight in the rear you have to move weight. its that simple
