jerrytubbs1
- Joined
- Mar 3, 2009
- Posts
- 350
- Reaction score
- 1
281
5r55s
n/a
4.10's
mt dr's II 305/35/18
Mods:300+ lbs weight shaved,jlt cai,u'd pullies,headers & full exhaust,alum. d/s,livernois stage 2 heads,hotrod cams,custom tune,3000 stahl,mt dr II's, lower and upper c/a's,k member,sway bar delete,anti squat brackets,a-arms,braille 15 lb'er,4.10's
That was my mods on the 11.67 run.Now I am adding a 100 shot.
So you get one guess- If you guess correctly, you will get 50.00 to spend on any products I carry.You have to write your answer in this format.
xx.xx you don't have to worry about the mph.
I will be running at the strip Sat. the 25th.I will post results Monday.My best time n/a this far is 11.67,I am running a 100 shot this time.Only one guess per person.The closest to what I run wins.I will pm KIMMER the answer and then post a time slip.
Since this is a points race tomorrow,I get 2 time trials.You are guessing the first time run.The car will have a 1 hour cooldown before the run.It will be 90 degrees here tomorrow.
That info should help you with your guess.
5r55s
n/a
4.10's
