Metal Clanking Noise in Rear End
perala487
i have a 2009 automatic gt 45th anniversary and for a couple of months i have been hearing a metal clanking noise when i accelerate and slow damn. Can anybody tell me what it is?
Hoonigan
I have heard a lot of people mention something similar and have had great success with differential bushing replacement with a polyurethane bushing. Also the rear upper control arm & mount.
weather man
Persistance Is A Bitch
MN
Could be LCA, UCA or the rear end itself.
is the rear suspension stock?
Benwhite911
V6'ing & Dealing With It
Cape Coral, FL
If you recently replaced your rear upper control arm, it may not have been torqued down properly. I did that about a year ago and experienced that metal clacking noise until I figured it out.
First step would be take a look around and check all fasteners and bushings.
slackinoff
East Texas
When I had some loose rear suspention parts, I would get a clank on accel/decell as the driveshaft took up slack. The loose bolts amplified the noise significantly.
Rm
