Hey guys. I have a question about belt slip after installing the under run pulleys. I have had the pulleys installed for a while with no problems. Now that it is in the high 40’s / low 50’s and damp in the morning, when the car is first started the belt squeaks a few times. After about 120 seconds it stops. I tried replacing the belt with a factory replacement, but I have the same issue. In the heat of the day it's fine.
Any ideas? I don’t see any adjustments on the tensioner. Do you know if I can adjust the preload? Should I get a shorter belt?
