29C: [FONT=Arial,Arial]Release terminals for the LB/YE wire and the LG/VT wire from the connector housing. Do not remove terminal from wire. These are the fuel sender wires.[/FONT]
[FONT=Arial,Arial]After carefully removing the blue lock from the OEM connector, look at the terminals inside the connector. If you look very closely you will see small locking tabs that secure each of the wire terminals to the plastic connector. CAREFULLY pry these locks back with a pick and pull the two wires from the OEM connector.[/FONT]
[FONT=Arial,Arial]STEP 30: [FONT=Arial,Arial]Insert fuel sender wires into the connector labeled [/FONT]SENDER CONNECTOR (2) [FONT=Arial,Arial]with the LB/YE wire going into the left side and the LG/VT wire going into the right (see Fig. 20). [/FONT]
Insert the two wires just removed from the OEM connector in step 29C into the connector of the FRPP harness as show in Fig, 20.
STEP 31: [FONT=Arial,Arial]Connect SENDER CONNECTOR (1) [FONT=Arial,Arial]into [/FONT]SENDER CONNECTOR (2)[FONT=Arial,Arial]. Once connection is made, the LG/VT wire should line up with the RD/YE wire and the LB/YE with the BK wire. [/FONT]
[/FONT]
[/FONT]
you brought me back in time..
man what a pain in the ass installing the dual pump was :S
ended up crammed on my knees behind the driver seat for a couple hours, and i remember struggling with these steps, as the plug that came with my kit didn't have the pins inside.. so i had to cut and splice the wires instead..
I am considering the dual fuel pumps. If you have the means, is it easier to drop the tank and install them that way instead of through the rear seat access panel?
