hi.. i am instaling my electric h2o pump and i need a schematic of the car to pick the propper wire to signal my relay pin 85 or 86 for the pump with key on ... whitout poking every wire with a test light or meter.......tia Simon.
thanks i did not see that before but it does not help me cause they where talking about a alarm system in case the pump failed andits not realy what i am looking for .. but thanks anyway
what i want to know is what wire to use on the car with key on to signal my pump relay...
loll no i talk to peter this morning and seen him yesterday and he does not remember witch one to use cause he used an other set-up cause of is s/c and i/c you by any chance dont remember witch one to use??
i sent a schematic to charlie from NH with the correct location and how to wire it in also has info how to wire it with a separate circuit that turns on the fan as well using a separate switch for cool downs at the track.
Charlie G. from NH can you please help him out and post the schematic i sent you...sorry i don't have a copy anymore
