Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,808
- Reaction score
- 31
Load on the belt. See they suggest a single V type belt, it will be too crazy to try to move it from another pulley?
It can't be much of a load. I would have to check to make absolutely sure though. The belt drive Meziere water pump that moves 100gpm only sucks up 7hp, the vacuum pump can't be close to that. 100gpm is a crazy amount of water. And you combo would take one of the smaller pumps.
As far as driving the pump goes I was thinking of turning one of the idlers into a double pulley. It would get driven by the stock 6 rib still but forward/outboard on the same pulley would be the drive for the vacuum pump. That way the drive "gear" could be nice and small so the pump is not over spun.
