Nitto 555G2 Long Term Testing
Norm Peterson
corner barstool sitter
RIP - You will be missed
Virtually all of the online wheel revs/mile and speeds in gears calculators ignore the fact that tire treads compress slightly in the circumferential direction as they roll through contact with the ground. So they end up turning a few more times in a mile than what the math based only on tire dimensions predicts.
3% is a reasonable correction in most cases, though this tread compliance correction for a few tires is slightly less (~1.5% - 2%).
So if you were to calculate a tire as being 750 revs/mile, you're probably going to see mfr-tabulated numbers more like 770 or a bit more. Trust either the mfr or this correction.
The online calculators really are well-intentioned, and since this effect is not exactly common knowledge among enthusiasts I'm not blaming anybody for making this oversight.
Norm
JimC
Any noticeable wear after 5k miles? How many 32nd were they new and what are they at now?
After 7,500 miles I rotated them again. They started at 9/32 and yesterday it measured 8/32.
SD_Stang
San Diego, CA
I'm running 275/35/20's on 20x10's Square and the tires have a good amount of road noise at 40-45. It's rather annoying after 8,000 the noise is still there. I wouldn't recommend them for 20 inch they may be quiet for smaller sizes.
Shotokan1509
CT
Per Nitto's website they make 285/35/20, but I don't see for sale anywhere?
Have you run other 20's in that size as comparison?
