klaw
Does anyone have EGT pyrometers in their FI 3V? Is it better to install them in a primary and get a more accurate reading on one cylinder or at the collector and get and average albeit further down the exhaust? What EGT's do you see at idle, cruise, and WOT?
I'm trying to track down a "problem" where my headers start to glow under cruise on the dyno. My tuner doesn't believe it's a problem with the tune and thought it was a physical cam timing issue. I've torn the engine covers off and confirmed that the cam timing is fine. The datalogs for the cruise look fine (apparently) but the session was aborted due to the header glow and the tune therefore is still far from optimized.
I'm planning on installing pyros in the collectors on each side to see what the actual temps are.
The basics are: 298 stroker at 9.1:1, stage III heads, stageII blower grind cams, Whipple HO at 15psi (Steeda 10-rib drive), 60#/hr injectors, Whipple monoblade TB, Kooks headers w/ catted X.
Any EGT data would be greatly appreciated.
