O/r x-pipe to headers?
Blackbird1084
Ok i've got a buddy down here that has an o/r x-pipe and it's tuned by bama for those. Will he need a retune for it going to the headers and an o/r x-pipe from the stock exhaust manifolds and o/r x-pipe?
fdjizm
Drag Queen
Yes headers change the placement of the front o2 sensors and a tuner will need to adjust for that (last time I checked)
CraigNnem
Thats what I thought too, till I called Brenspeed to get a revised tune. They told me until you get a Check Engine code & wright it down for them they wont know what to do in the tune.
Its been about 5 months & no codes yet.
Blackbird1084
But wouldnt it be turned off already because of the o/r x-pipe(catless) he has now? I'm confused.
redfiresixer
Regardless he should get a new tune. Whether or not it is absolutely required the revised tune will provide more power with the new headers.
Hatchman
Stangless
Chesapeake, VA
If he's got an o/r x-pipe tune from Bama, Doug has already turned off his rear 02s.
I assume he is going to shorty headers? If so, I don't think he would have to get a tune. The stock manifolds actually flow pretty well. But they look like rusted crap.
Long tubes, then yes, I would get a tune.
1bad65
Austin, Tx
I'd get the car retuned.
When I went to an OR H-pipe I retuned the car. I took that off and went to hiflows, and got a retune again. I've saved the old tune so if I do go back to the OR H, I'll just have to reload that tune.
94tbird
4R70W FTMFW
not tech, moved
and he should get a retune, yes, considering the 02 transport delay will be off at minimum thus clicking on the check engine light
Hatchman
Stangless
Chesapeake, VA
not tech, moved
It's already tuned for an off road x, so the rear 02s are already turned off so it will not pop a code.
Hatchman
Stangless
Chesapeake, VA
I'll tell him to call bama and see what they say.
So what did Doug say?
Doug tuned my car, way back in '05. Picked up 27rwhp in one run going from stock to a JLT intake and Doug's tune.
A couple weeks later, I put on an off road H pipe and went back. Besides turning off the rear O2, there was no change needed in the tune whatsoever, every thing looked exactly the same, except I picked up 6 rwhp.
With headers, mid lengths, yes I think he might need a tune.
Blackbird1084
He talked to them and they said it would need tuned for lt's since the o2's are moved so much further back.
NA-Stang
AMC #8 aka "The Jockey"
Now Im confused.
What does it matter where the hell they are? Shit, mine aren't even plugged in! I have caps on the bungs.
Hatchman
Stangless
Chesapeake, VA
+1
That doesn't make any sense. Whether you have an off road mid pipe and stock manifolds or a set of long tubes, the rear 02s are turned off. So it doesn't matter where they are, even plugged in or not, they are off. There is no cat so there is no change on O2 for the O2 sensors to detect.
Blackbird1084
I'm just going off of what i was told. I don't know why it really matters either.
Weou09
Bham, Alabama
Geez guys he is talking about the UPSTREAM O2s not the the downstream...Yes you will 100% need a new tune if not you will get slow response codes for the front O2s because of their new location.
