O2 Sensor Woes
Blue07GT
South Jordan, Utah
Well I've been fighting my car for a while now with trouble codes related to the exhaust(LT's with Catted X). I was throwing codes of too lean and too rich so I replaced my bank 2 sensor 2 02 sensor with an aftermarket one from auto zone, this didn't work so I put in restrictor's to bring the sensors up out of the exhaust. Well that cured my lean and rich codes, but then I started throwing P0161 so I switched the rear sensors and started throwing P0141. I would simply put the old sensor back in, but I broke the connector putting the aftermarket one in. Does anyone know if our cars don't like aftermarket sensors? Bank 2 Sensor 2 is the rear passenger and B1 Sensor 2 is rear passenger, right? Any help would be appreciated, thanks,
remainvayne
I do know that the O2 sensors are quite finicky & most guys recommend going with just OEM sensors.
slow06stang
Arnold, MO
I recommend oem, I had problems with aftermarket ones so I switched back to oem and have not had a problem since. Did you have your car tuned for long tubes?
lito
Caracas, Venezuela
B1=passenger, B2=driver.
You need a correction in your tune, contact your tuner and tell him you have aftermarket cats with your LTs. Only use OEM sensors.
Blue07GT
South Jordan, Utah
I do have long tubes and I have tunes from two well known companies and both told me to go back to the place I got my exhaust and tell them my cats are bad. So p0161 talks about the driver side and p0141 is passenger? I was told it was the opposite. With one of the two companies tunes I was throwing codes without a cel, can they turn it off in the tune even though codes are thrown?
lito
Caracas, Venezuela
Nothing like visually inspecting the cats, a scope is ideal but not everybody has one. If they are good, you know were to look for issues.
Aftermarket cats are different than stock and require different settings, they can turn all of that off but then you'll end without having the protection enabled (if it still is used in the tune) and the warning of a plugged cat.
Blue07GT
South Jordan, Utah
Yeah, I pulled off the pipe and sent pictures of the cats from the top of the pipe over to the exhaust company. They told me the cats didn't look bad so I was sent the restrictors which solved the lean and rich codes, but still no resolution on the 02 sensor issue. I'll give Ford a call tomorrow to see if they can shed some light on this. As far as tuners being able to mess with the rear 02's I've been told by them that all they can do is either turn them on or turn them off and they don't have the ability to do anything else.
lito
Caracas, Venezuela
Yes, the thing with those codes is that they are heater related, those codes are thrown if you have your rear sensors disconnected, or bad sensor/wiring. These are narrowbands that use 4 wires, 2 for the heater, 2 for signal. The heater use a positive wire that comes from a BEC fuse (47, think) and the PCM uses the switched ground to control it. The other two wires are for signal. They are separate circuits, both monitored by the pcm.
I would check that you have the correct sensors on the correct connectors, fronts are green, rears are blue, sorry to say this but I have seen any combination you can imagine, inverted fronts, blues on a side and greens on the other when people do header/transmission work. Also would check the wiring harness because if sensors are correctly plugged and you still get these codes, there is a harness issue, a point to point check would help.
The CEL can be turned off in the tune. You can do both, just the CEL or the code altogether. (some codes)
No, if using SCT hardware, there is something else to be done.
