Beagle
- Joined
- Jul 17, 2009
- Posts
- 6
- Reaction score
- 0
Hi,
Can anyone tell me what happens in the transmission (5R55S) when you
set the o/d lockout to ON.
I have lapped my car several times, always with the o/d lockout on, it
has always worked fine, new fluid / filter / oil temp gauge, not being too hard on the transmission. The last time out it would work ok for about a bit, then the car would
shift as if the o/d lockout was not on. every gear, lockup etc... just like it was in DRIVE I reset the battery, the fluid temp.
was at 180° also if you tried to geared down manually (TCI Ratchet Shifter) you would have to give the gas pedal a little tap to get it to gear down.
Going home and ever since then, on the street it has worked perfectly.
Just would like to know if I could find out what might have happened.
What function does the OVERDRIVE LOCKOUT button control.
Thanks for any info,
Bob
Bob
