Saleen4971
of course, these codes pop up after ive worked almost 2 weeks straight......
heading home from work, sudden engine buck (zero power, then came back fine) - at the same time, battery light flashed VERY quickly, CEL came on (with P0607 and P0480), temp gauge pegged hot (returned to normal a few seconds later), security light lit up, and "check gas cap" on odo.
happened again and again on my way home (5 mile drive, cant count how many times it happened......)
when driving, it feels like you hit something. at idle (stopped at a light, etc) it nearly (and one time did) stalls.
i have had an odd belt noise during decel lately (last 2 weeks or so) so i am leaning towards a bum alternator/pulley, especially after reading a bit on "odd codes and combos" as well as the purpose of the clutched alternator pulley we have.
tune has been loaded without change for years, new interstate battery installed this past winter, 65k miles.
any other common issues i should look for? ill be swinging by work in the morning to run a test on the batt and alt, although its not a true load test sadly.
