Paxton Novi 2200 Head Unit For Sale
xxxcobraxxx
Ventura, CA
Selling a brand new Paxton Novi 2200 Head Unit.
CCW, Polished, Oil Fed
Capable of Supporting 1000 HP. Billet front gear case cover.
Upgrade your existing Vortech Si, T, or Novi 1200!
Decided to Use a YSi instead.
$1800.00 Shipped.
Thank you.
degmidget
What do u need to mount the ysi? I have a 2200. And what is the difference between the ysi and 2200? They have the same inlet and outlet as the ysi?
konablue11gt
Evansville IN
I think this is the competition head unit as he says oil fed so an oil line has to be tapped to feed it otherwise it should be the same mounting depending on how its clocked
xxxcobraxxx
Ventura, CA
YSi bolts into the same location. Outside dimensions are physically the same. YSi will support 1200+ horsepower. It doesn't have the low end boost curve of the 2200 though.
xxxcobraxxx
Ventura, CA
Is this a direct replacement for Vortech V2/V3 head unit or do other changes need to be made?
Physically its a direct replacement. You will also need 2 couplers. One for the inlet (4") and one for the outlet (3").
degmidget
I need a head unit now my 2200 crapped the bed! Where did you buy your ysi from?
