Please delete
JC SSP
FL
Perfect! I have factory Ford 18" "funnel" rims, I would be interested to know if the 13" front brakes fit. Thanks in advance. :)
pass1over
I like it LOW
Trenton, FL
I've got the original front calipers off my '12 GT (painted red) if anyone wants to upgrade. I switched to a Brembo setup about 2 years ago.
Laga
Chicago
Wilwood 6 piston brakes fit easily, front and rear, on 18” wheels on my 05.
AHaze
Edmonton, AB
This swap just moves your existing caliper out radially by around 1/2". If you have over 1/2" of radial clearance between the caliper and wheel now then you're good to go.
pass1over
I like it LOW
Trenton, FL
Will they fit an 2006
They should. You don't need them, I misread the post originally. They're the same calipers that came on an 06 GT, you're just upgrading the rotor size
Just like you can upgrade the rotor size on the rear with a bracket and use the larger diameter Shelby rear rotors. Same caliper, just a bigger rotor
