Power and ground question.
Insaneba
I have an 05, and when I wire in the power or ground for my gauges and shift light, the car will not start. Almost as if its triggering the security system. Anyone else deal with this problem?
06monera96
LeShawno
Ontario, Canada
need more details.
Where are you wiring the gauges?
What gauges?
Are you wiring ground or perhaps the feedline?
Insaneba
Sorry, should have been more specific. I'm grounding at the drivers driver's side floor board, at a factory ground location using a factory bolt. Power for the gauge lights is being pulled from the headlight switch, and the gauges are a mechanical boost gauge, and an afr innovate gauge. The raptor shift light is grounded at the same place, but pulls signal from a cop signal wire. Power for it is in the fuse box, can't remember which circuit.
datmbn
Sweden city Motala
You can not take Power from the headlight switch, it is just an "grounding" switch that Controls the behavor of the SJB (lights on or off)
Insaneba
It works for illumination, which is all I'm pulling from it. But that must be why its triggering security when I try to start it? Where do you pull light signal from?
06monera96
LeShawno
Ontario, Canada
you are back feeding the sjb....
You can't use ANY wiring from SJB they are all ground control activate hot all the time.
You gotta run power from the sjb via a fuse tap into the power required devices
For signal, i think you need a tac adaptor?
RocketcarX
95% of my weight is fuel
Colorado
I had my autometer gauges with LED bulbs tied to the dimmer circuit in my 08 at the switch with no issues. Are you using old school incandescent bulbs?
Insaneba
One gauge is led bulb, the other is an innovate afr digital gauge.
